Any reason why my bridge pier footings are not seeking existing ground on the proposed surface below? The bridge footings seek ex ground when it hits the ex file but not proposed. see picture.
Hello Chuck,
This is a defect and I have filed a request to repair entitled "Defect 735574:Bridge footing project to proposed surface".
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: Chuck K.
Was this issue ever resolved? I am running into the same issue. My project is along the coast of Georgia and the columns target the existing ground until the bridge starts to cross the water. I suspect there is an issue with the elevations of the surface going to negative values since I am at sea level in this location? Any advice will be appreciated.
ConceptStation version 10.00.07.27
In our next update, you will introduce the ability to change the Z offset on each/all pier footings. This next update should be available in early October.
Simon
