When I Create Drawing, I get confused about these scales.
See the pictures below.
The Scale in Place Named Boundary Civil Section dialog
The Scales in Create Drawing dialog
The Scale in References dialog
The Scales(Annotation, Design, Paper Scale) in General Properties of Sheet Model
1.Could you please introduce these scales above? What are their functions ?
2.Which Scale decides the Scale in References dialog of Sheet Model?
Basically, I Want to only adjust the Annotation Scale in Sheet Model, then the Sheet Border will be automatically scaled base on the Annotation Scale, at the same time the referenced drawing model will not be scaled, and the scale of referenced drawing will always be 1:1。
3. How to set these Scales to achieve this function above?
Looking forward to your reply.
Thanks and best regards
hi Chen,
here are some useful links to understand the different scales:
https://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/mark_penns_blog/posts/usability-of-annotation-scale
https://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/mark_penns_blog/posts/annotation-scale-in-create-dynamic-views-dialog
https://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/mark_penns_blog/posts/scales-in-microstation
Answer Verified By: Zhengpeng Chen
