Geopak CR - Minimum length Contour to Label
I am currently erasing a lot of of extra index contour labels (the labels are large since it is a large scale drawing) I have lots of small index contours that form small closed loops (The TIN is LiDAR generated, so I have lots of these). Each contour gets a one label no matter what the label spacing is. See Screenshot
An option to have a minimum length to have a contour be labeled would be nice, whether is user inputted, or hard coded to some factor of the label size.
TIA
Dan
  • Hi Dan,
    while this response does not directly concern the placement of contour labels (nor the discussion that has followed about contour label placement)... I though it may be applicable to your current situation - maybe.
    There is an option on the Load DTM Features>Contours dialog called "Minimum Area". The way this works is this: If there is a closed contour whos area is LESS than the value in thie field - the contour will not be drawn.
    So - given that the data you received was Lidar and there may be LOTS of very small contours that really dont add a lot of value when shown - this option may be applicable for you... maybe :-)
    Quickly measure the area of some of these really small closed contours. Key in a value that is larger than what you measure and see if the result is more to your liking.
  • Okay...maybe the functionality isn't that nice but there is always room for improvement.  I really haven't used the tool too much but I know it is there.  An "intelligent" contour label woudl be nice.
