When using Annotate Model tool, I find that no matter what annotation group I select, only the first annotation group (XS Grid w/ Annotation) takes effect.
What’s more, I delete all the other Cross Section Annotation Groups in Feature Definitions Metric.dgnlib file, except for my own group, XSANSE_Pave type 1, see the screenshots below.
And I have checked, there is only one Feature Definitions Metric.dgnlib file in my environment, and I have deleted all the Annotation Groups definition in other dgnlib files.
In my design file, Design Model.dgn, I can not find any Annotation Groups, even applying Cross Section Annotation Groups, and even re-opening the project explorer.
So, it is a big problem for the sheet annotation.
How to solve this problem?
It is the ORD Update 1 version.
Specifically I do not think it is an efficient way to communicate via this community, Could you please give me an email address of ORD technical personnel?
Thanks and look forward to your reply!
Chen Zhengpeng, your SELECT user
Chongqing Communications Planning, Survey and Design institute.
Could you send me a copy of your DGN and dgnlib for testing? My email is sanders.thomas@bentley.com. If your dataset exceeds 8MB, please let me know (via email) and can send a link for uploading your data.
Thanks!
Thanks for your reply! I've send these files to your email.
I am having the exact same issue. Would like to see how this works out.
Hi Chen,
Open Design Model.dgn and select your Default (Master Model). Select Explorer>OpenRoads Standards>Design Model.dgn (Default) your Annotation Groups should be displayed in the Active DGN. If you delete the Annotation Groups here, they will not be listed within Model Annotation’s Annotation Group.
Also for testing purposes, in XS Grid w/Annotation, I removed the Left Slope annotation and when I applied this Annotation Group, no left slope was annotated. If needed, I can create a video demonstrating my steps.
Please test, we should have the same results
Sanders
Answer Verified By: Zhengpeng Chen
Hi Sanders,
According to your wokflow, I have delete the redundant Annotation Groups.
But, it is weird, because It is only in the Default Model I can delete the Annotation Groups, and they are invisible in 3D model and sheet model.
Thanks very much!
