Good afternoon,
I am trying to run my templates through the corridor, when I get this error:
"Error - Corridor Template: There is no profile for this template corridor"
I first noticed this when I went to apply a vertical point control to the proposed grading point on the outside of my MSE wall, but it didn't change anything. And now I keep getting this error when I process the corridor and I'm not sure what it means.
Let me know what is needed to further diagnose the issue, if needed.
Thanks,Ken
I just encountered this exact issue. For me it was the profile of an alignment not being active. There was a corridor attached to an alignment whose profile was deleted and created again, but not set to active. This corridor was used for many point controls on other corridors. Once I set the profile to be active, the error did not come back.
Answer Verified By: Ken Harrison
Yep. This did the trick. I should have updated this thread after someone from Bentley discussed it with me. The issue was indeed that there was not an active profile.
