When we import a raw and control file from Lieca Viva TS 11 , I am getting all features connected to each other. I know what setting to use in old InRoads but the same settings doesn't work in SS4. And other question I have, is Project Explorer and Native Inroads box still don't talk to each other? and if they do , what setting I have to use.
Hi Hemangini,
When you say "When we import a raw and control file from Lieca Viva TS 11 , I am getting all features connected to each other." are you referring to SS2? And when you import into SS4, this is not happening? What exactly is the problem that you are having, and how are you importing the data?
This video shows how to import raw survey data using SS4 OpenRoads functionality: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/27199/importing-and-editing-raw-survey-data. It could be that you did not link your XIN to your Survey Feature Definitions. This video shows how to do that: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/27554/edit-and-linking-survey-feature-definition. Please try this. If you are still having a problem, please give me more information on what the problem is.
Holly
hey did you had chance to check my data in SS4 system?
You have my xin . What I am requesting you is to try using my xin & importing raw files with the steps I sent you. In the new doc file the image in the bottom of steps is the resultant image I am looking for and other image is the one I am getting.
I suspect there is some thing wrong with my sin or my Inroads setting.
once you generate graphic from the raw files you will know what I am talking about. and please send me a snap shot of what you get using those file. So I can compare it.
One more thing, I can import raw files through Inroads native box but I am not able to see elevations. I can only import my survey raw files with project explorer.
I am able to see the parking striping.
Thanks girl! This is what I was asking.
and you used my xin, so there should be some thing going on with my survey settings (with link codes or something ) .
can you send me your file so I can open it and compare my settings with it?
I am also getting Random shot connected like grass, highway signs
did you try some other data process with my xin file?
Does it look right?
I sent you an email.
Your data looks ok . I don't know what wrong with my setting. I guess my Xin might be ok.
