In large projects, often there are multiple files representing different areas of utilities, which creates the need to have a conduit connect to a node within a referenced DGN. When ever I do this, the program shuts down entirely or does not allow it to happen.
Is there a patch coming to fix this? This is quite important to do this as to ensure data uniformity across a project.
Thanks.
We currently have a defect logged for this issue with trying to select nodes or links from a reference file and causing a crash. It allows you to select the first node but as soon as you hover over the second node to connect the conduit, it gives a .NET Framework crash. The defect logged is: Defect 725505.
Defect 725505
Answer Verified By: Alex Badaoui
Thank you.
