[OR SS4 .878] Roadway Designer combine parametric constraint with change template origin
Hi.
I have created a pipe template with parametric radius. This template is created with the origin at the center of pipe.
Some times I need to apply the template based on bottom of pipe (BOP) or top of pipe (TOP).
I assumed that I just could right click the BOP point and select "Change Template Origin". However this does not work well combined with parametric radius. It just keeps the parametric value set in Designer.
The Template is created with Radius set at 0.25. The applied corridor has a Radius of 0.5.
My current workaround is to apply a point control at the center of pipe, but I would like to know if anyone has any tips that enables me to solve this only with ONE parametric constraint and no point control.
 Default parametric value in template
 Changing template origin. Does not inherit the parameter from the selected point (BOP).
 Parametric constraint in the applied corridor.
XSection result when I am using "Change Template Origin". The bottom of pipe should be at 0,0.
 Workaround with point control at center of pipe.
 With point control, the bottom of pipe is at 0,0.
I was not able to attach the itl-file. Please use this link if you would like to test the template.
https://akersolutions.sharefile.com/d-seac05cec040429da
Thomas H. Stavik-Karlsen
Subsea CAD Engineer
http://www.Akersolutions.com
Parents Reply Children
