The following text describes the issue that we are running into when trying to import a new ASCII text file into a survey basemap drawing.
PROGRAM BEING USED::::: ODOT cadd Power GEOPAK SS4 - Version 08.11.09.878
Using the Survey Menu; create a new dataset, specify the text file to import, once import has started a box pops up warning us we are about to overwrite a point (ie: CALC1002), this point did not exist in the GPK prior to importing this new text file.
We select the option to add a prefix to the point number that is being overwritten (ie: ARCALC1002) and hit apply
After applying, it continues to warn us that we are overwriting more points that did not exist in the GPK prior to this import (ie: CALC1004, CALC1005….) and it keeps wanting to overwrite the same CALC point over and over again (2 or 3 times per point), adding 1% to the total import every time.
SUMMARY: it keeps wanting to overwrite points that are being created from the same DATASET that I am trying to import, even though these CALC points did not exist before selecting the new text file.
what are solutions to fix this? We cant import any other text files without it trying to overwrite points that didnt exist until this import
I think it violates the naming convention for points in the GPK. 8 Character max. We increased the length to 15 characters but I do not think Survey points was included in that. Mostly for Chains.
We are still having issues when trying to create new projects in both the CADD standards microstation and the old V8i standards microstation, completely blank GPK/PRJ/PCF files, try to import the first data set and it crashes without importing a single point.
Along with that issue we are unable to select Build DTM using SMD features when trying to create TIN files. we are only able to use all points and chains which uses every point that we typically do not include in a surface (ie: trees, pavement markings, etc.)
any solutions?
