ConceptStation Alternative Intersection
I am new to conceptstation. I am working with alternative intersection designs such as RCUT’s and Displaced Left Turn Lanes. I have tried several things to create these in conceptstation with little success. Any help or ideas would be great. I’m not really sure it can be done efficiently using conceptstation.
  • Mike, you are correct, currently CS does not efficiently handle median openings. You can try using a combination of different templates but even those will want to transition to each other and assuming your CL is indeed down the center, transitions of various templates will probably not work. Could you provide your files (DGNDB as well as DGN depicting desired results) for us to use as we add this to the enhancement request backlog?
