OR InRoads End Condition Forced Tie-In
I need an end condition to locate HZ Features for Exist ROW & Fixed Tie locations, determine the lesser horizontally, and seek up/down to force-tie to the existing surface. Must stay in the ROW, can't go beyond Fixed Tie feature, if present, tie vertically to surface whether cut or fill.
I tried some ways, but don't get what I need.
For example:
I made DNC point, no construct component from Hinge to seek HZ for fixed tie, constrain HZ to Feature (with ample range).
I made DNC point, no construct component from Hinge to seek HZ for ROW, constrain HZ to Feature (with ample range).
I construct component from Hinge to FixedTie point constraining HZ Min, parents are previous DNC points and Vertical constraint seeks Active Surface Any Direction (with ample distance).
Results in indeterminate solution.  Forcing
Any ideas how to accomplish?
