I have a model file which has existing terrain data that is out of date. I want to replace it with newer .DEM terrain data in ConceptStation. Perhaps I am missing a simple command here but could someone explain how this is done? Thank you.
- Ian
Export the ground to a .tin file from ConceptStation. Use the tin file to create a terrain element in a new dgn. Store the terrain into MX model file (for example).
Thanks!
