Editing GDF file outside GEOPAK Drainage
I have a gdf file that crashes even before opening.
It all started when I somehow goofed up while building a drainage network, it froze and crashed.Later when I tried restarting uStation and reopening the GDF file, it tried building the topology for the network that I goofed up, and it crashed again.
Since I am unable to open the file at all, can the GDF be opened in an editor outside of Geopak so that I can manually delete all the components of the drainage network that's causing the issues? I used to be able to edit Inroads S&S files in MS Access. Is there a similar software that can handle the GDF?
I am attaching the GDF herewith, and the name of the drainage network that causes issues is "OUT442N" in this file.
thanks,
Vinod
