I created a corridor with no problems. I want to "add corridor reference" to a tie into draped surface line on each side of the corridor. One side worked fine. The other side added the reference to the corridor but the graphics did not mesh over. Therefore the cross sections did not tie out on that side. I checked to make sure the tie in is within the terrain. I also check the template and tested that. Both tie in lines are defined with a feature definition.
Any suggestions?
Hi Myron,
Do you have End Condition Exceptions or Point Controls on the side of the corridor that fails?
I'd be happy to take at your data if you'd like, data can be uploaded here https://bentley.sharefile.com/r-r26cf35cfc4440419
Sanders
No end conditions and no point controls at this time.
I will send you the GPK file and dgn files.
Data received. Thanks!
