Hello, I am designing a template that involves a standard two directional curbed road-way (split between two templates (one for left and one for right)) with sidewalks (shown as a vertical line with no horizontal dimension) adjacent to the curbside, and several back slope end conditions tying into existing ground (see below):
With a parametric controlled switch display rule showing curb, or open shoulder.
Now, what I want to do is create a trigger line on the curbed section that will put a retaining wall when ever the back slope becomes greater than 4:1, and if the back slope is equal to or less than 4:1, show no retaining wall.
I have this so far:
but I'm not sure how to get it to do what I want it to. Any guidance would be very appreciated.
Thank you.
I also want to add that I want the retaining wall to have a back slope of 4:1 (when displayed), that ties into existing ground.
It could also work for me to create closed shape which seek after active terrain. Hov ever I am not sure how I create display rule for the cut and fill shape.
Thank you this was exactly the answer I was waiting four years for.
