All day, I just restart the program, which still crashes and reports a number of bugs. Reopen the program, click on the first line, change the definition, and again the out of memory error. I Can not move with geometry, everything reports bugs. I deleted all reference files and remain only 15MB large file, but without effect, nothing can still be done. Of course, the system has 90% of free memory. Ok I delete all parametric constraints (often cause mistakes) and finally something can be done, i can move with geometry again! But parametric constraints can no longer be imported back, or create new ones, all causes errors, only open menu objects of the corridor causes a error (out od memory)... I can start making a corridor from the beginning again and hope it will not happen again!! Is there a user who is satisfied with Powercivil SS4, especially in the Czech Republic? So for me, buying this malfunctioning program is a terrible mistake and I hope this is my last work with this program. If anyone is considering buying this program, it's a clear madness.Your pissed user !!!
We're having a similar problem with PowerInroads SS4. Crashes, out of memory errors, hanging with the blue wheel of death...But we can't use SS2 (stable) or Connect because of our client requirements. And of course, now that there's the new edition out, Bentley has no interest in fixing any of the bugs left in SS4.
MaryB
Unfortunately using SS3 and / or SS4 on an active project was not an intelligent move (IMO). ...and anyone 'requiring' it had been misinformed as to its future.
Welcome to working with the Government...
Not true with my informed Government "Zen Friends". ... this is the last that I'll say on this topic. Moving forward, ORD is the only place to migrate to.
I had bugs too but after cleaning regs from regedit I don't have problem now. I had problem creating dtm from dxf, the program clashed. I attached dxf as reference and I made DTM without clashing. The program were clashing when creating 3D objects. After cleaning reg files it worked :) I think cleaning reg files about Bentley and referencing CAD files may minimise bugs.
