In InRoads SS2, In a template, I could set a style constraint for a point to be horizontal, vertical, or both. In ORD I am only seeing the option to set a Horizontal Feature Constraint. What happened to the vertical option?
Mike,
This feature has been discontinued since SS3. I have not heard of any plans, to date, to bring this back as point controls can be used in lieu of its absence.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
I have horizontal style constraints and display rules to turn off components and end conditions, unlike SS2 where is was not a common practice to edit the template drop, ORD makes you edit the template drop and remove components as necessary.
So, it looks like to me you have to edit template drop??
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
Joe, this is not the case (you may have misread the original inquiry)/ Horizontal Style Constraints are now called Horizontal Feature Definition Constraints and behave identically to what you have previously used. It's the vertical aspect that has been removed.
