InRoads SS2
I have a pavement section that I need to split into two separate components for left and right side shoulder reconstruction. The only way I know to accomplish this is to delete everything on one side, then completely reconstruct the now missing side. Is there another way?
Hi, sorry for reviving an old thread but this is the method that I've used most commonly when creating a template. I'd normally take from other pre-existing library templates and edit it or drag and drop something like a shoulder and remove the curb.
However lately I've been noticing that the roadway designer is glitching on me. The new template (lets call it Template B) looks and function perfectly when dropped into a station eg 10+000 for every 20m. At 10+000 it looks perfect however at 10+020 and beyond, the attributes from the original Template A begins to show up and all glitched/invisible. Some constraints have disappeared. Note that several points and components have been deleted from Template A to create Template B and is no longer found under the active tab.
I believe this has something to do with deleting points and constraints from template A but why is the properties from Template A still carried over to Template B?
Are you saying this regarding InRoads SS2?
Yes
