Hi all,
How to create a terrain by OpenRoads Designer using GIS contours? Then, how to add survey points to the terrain?
Any response is really appreciated.
Charley
I wouldn't use GIS contours as they are simply interpolated lines so you going to build in inaccuracy.
You should go back to the raw survey points and use the terrain modelling tools to create a terrain
Hi Martin,
Thanks for your reply. What method shall be used to create a terrain by the survey points in terrain modeling? Thanks again.
Take a look at this video I created - it will explain
https://vimeo.com/189516637
Martin
That is not OpenRoads Designer!
Where are the InRoads DA/Survey Tools within OpenRoads?
Frank
The way I have shown is using the terrain modelling tools within MXRoad V8i SS4.
The procedures in Openroads Designer are exactly the same
Hello, How could be posible to add survey points to Openroads if the software has deactivated the Survey Option to import ASCII files into the dgn as COGO points? I need this option since it release but Bentley are not responding to this requirement.
There is an option to import XYZ points from ASCII file using Text Import Wizard and add these points to an existing TM.
Why you are not using this? As long as I understood it does exactly what you want.
