Hi all,
How to create a terrain by OpenRoads Designer using GIS contours? Then, how to add survey points to the terrain?
Any response is really appreciated.
Charley
Hello, How could be posible to add survey points to Openroads if the software has deactivated the Survey Option to import ASCII files into the dgn as COGO points? I need this option since it release but Bentley are not responding to this requirement.
There is an option to import XYZ points from ASCII file using Text Import Wizard and add these points to an existing TM.
Why you are not using this? As long as I understood it does exactly what you want.
