I have an issue with adding point Control to a template drop, there are different points not visible in the list?
Any idea?
regards
//Christiaan
I also tried to test with training templates and that's not working either.
Please help
Hi Christiaan,
Found the workaround as we discussed. Select a random point and change the point from the point control list. Not perfect but it works. But I filed defect 763347
Ernst
My issue is, I have a point in my template that has not been constrained. The point is a CL of a median barrier that needs to follow a horizontal alignment. The point is not being listed is the Create Point Control tool.
Please help!
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
Hi Joe, Try to use another point en when the point control is finished change the control point to the one that was not in the list.
