Has anyone seen this problem and a correction for it. Putting this out on the forum since it deals with FDOTSS4 workspace environment using the FDOTSS4.xin
have one user when Using the Create Cross Section tool from Corridor Modeling, selecting the preferences to choose a preference when in GEOPAK SS4 (08.11.09.878) the dialog is blank. Opening the same file and using the same XIN opening in by others in GEOPAK SS4 or Power InRoads SS4 (08.11.09.878) prefs show in the dialog. I am assuming the preferences are coming from the XIN since the dialog looks like the InRoads Create Cross Section dialog.
NO preferences
Preferences showing:
This adding the xml dll's from Microsoft fixed the problem.
Answer Verified By: Marcus Blake
where do you download the xml?
There is a file from MicroSoft mentioned in this Wiki Article: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/31445/xin-is-blank---preferences-and-styles-lists-are-empty
It's not an XML file, it's one needed to read certain XML files.
MaryB
