I created a new file which references my alignments to use for superelevation design. Let's call this the superelevation file. I created the section and lanes and ran the Calculate Superelevation tool to build the transitions automatically. However, I had to make edits and manually changed quite a few of the stations and cross slope values. I then saved the file and referenced it into a Corridor file where i built the corridor and assigned the superelevation to the template.
Everything was working fine... however, now a week or so later I was checking some cross sections and realized that the lane cross slopes were not correct. I went back into my super elevation file and see that all of the stationing and lanes are incorrect...it seems to have reverted back to what was automatically created from the Calculate Superelevation tool. All of my manual changes were lost.
I am unsure how this happened because I was not working within the Superelevation file...only the corridor file had referenced it. Does the Process Corridor command automatically rebuild the superelevations? What even happened to my manual changes? I think I can find an older version of the superelevation file but want to lock it or something so this doesn't happen again.
Thanks for your help
-Justin
Nebraska DOT users have experienced the same thing. After discussing this with Bentley Support, it was decided to have our users "unlock" the superelevation rules if they do not want them to automatically update.
Tom SawyerIT Business System Analyst SupervisorBusiness Technology Support DivisionNebraska Department of TransportationThomas.Sawyer@Nebraska.gov
Upon further inspection I don't believe that it reverted back to what was created with the Calculate Superelevation tool (using given design speeds and e values). However, nearly all of my stations and values of full super were changed and I had to manually change them back. I viewed the superelevation report and saved a text file which I hope I can use if this happens again...however, I am curious as to why these values would have changed.
Thanks for the reply! I saw that button but wasn't sure if it did anything. I'll give it a try.
