Hi. I changed the subject's title because major problem is stationing and location discrepancy between plan and profile model. I created alignment from Inroads' Text Import Wizard. The beginning of station is 8+552.45km. After imported it from Import Inroads from Memory, alignment's start station is 0+000 in plan view, but its start station is 8+552.45 in profile view. Although station of vertical alignment is true for profile model, its location is wrong. Part of vertical alignmen is out of the terrain model. On the contrary station of horizontal alignment is wrong, its location is true. In plan model I changed start station value from 0+000 to 8+552.45, but profile model didn't change. How can I fix vertical alignment? Why is start station of the alignment imported from Text Import Wizard zero?
Version:Power Civil ss4 08.11.09.845
Screenshot:
Data:https://we.tl/h523thyl75
Right Mouse on active view. Click on Inroads Tools : Explore Show/Hide > Geometry > View Geometry > Stationing. Did you export to ALG upon changing start station value from 0+000 to 8+552.45 and read this revised ALG into Inroad Explorer? Hope this helps Regards GC
Hi Gary. Thanks for answer. I applied as you said, it didn't work. However I convert the alignment to LandXML and I opened it with text editor, I deleted vertical alignment text in LandXML. I created a Python script which converts vertical alignment text file to LandXML vertical alignment format. I converted vertical alignment parameters to veetical xml and copied-pasted it to main LandXML and reimported it. Now profile is suitable for horizontal alignment.
Answer Verified By: Edip Ahmet TAŞKIN
Hi
Can you share link to a simple LandXML horizontal and vertical alignment format?
Gary
