Is there a workflow to create a terrain from a corridor without having to select each element of the corridor?
I tried this technique (https://www.youtube.com/watch?v=P68RoK9hH_M&list=PLnJUnxLwu_N6bmJnO4jSyVmADThsPyx1X&index=3) but a terrain model was created using seemingly random points from my template rather than just the top surface. I did not see where to chance the design stage to top mesh when using ORD.
As I said, you would need to create a 'Top Mesh' feature definition for the corridor. Easiest way is to amend the setting of a feature definition that you already have e.g. Design.
