It maybe my eye sight, but when using OpenRoads Designer Connect Edition 1
1. How do I change the text orientation so that the top of the text is on the high side of the contour line?
2. How do I get rid of the 'm' in the metric contour text?
Mark: You are right again. The terrain is in a reference file and the 'm' problem is solved.
The text orientation is still an ongoing problem.
Thank you
David E. Stewart
Calgary, Alberta
ORD 2022R1
