In OpenRoads Designer, How to enable the basic Microstation AccuDraw?
In Power Inroads, turning off the Toggle Civil AccuDraw and turning on Toggle AccuDraw can enable the basic Microstation AccuDraw. but in ORD, it can not.
Looking forward to your reply!
Chen Zhengpeng
Chen
thank you for bringing this up. I can reproduce the problem and I filed a defect. Once you activate Civil Accudraw, the regular Accudraw will not activate. You need to exit and come back in for it to work again.
Defect 768728:Civil Accudraw Activation causes Regular Accudraw to not work anymore
and Vice-Versa
I am currently using update 3 of ORD and do not have the ability to toggle back and forth in the same work session. Is this still pending resolution or has it been addressed in update 4?
you need to Disable CivilAccudraw then you can toggle accudraw back on.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/142177/in-openroads-designer-how-to-enable-the-basic-microstation-accudraw
The issue seems to be as described above. Once civil accudraw has been toggled on once, regular accudraw can no longer be toggled on even if civil accudraw has been disabled. You have to exit out of the file and reopen. See video below:
