OpenRoads ConceptStation .ird file fails to export
Hi everybody
I am desperately trying to export out my ConceptStation file to OpenRoads Designer to work on it further and with more tools.  I followed the instructions on the wiki on exporting but I get an "export failed" error on just the .ird template drop file.  Everything else says it exported without a problem, but that template drop file is pretty important...If I can't get it to work, I am pretty much back to square one and have lost days of work.
When I try to import the .ird file into OpenRoads Designer, I get an unexpected error that an "unexpected end of file has occurred.   The following elements are not closed:  Corridor, RoadwayDesigner, InRoads, Line 1, position 3942445".
I really need help on this issue.  Do I uninstall and reinstall ConceptStation?  Is there something wrong or damaged in the ConceptStation file that needs changed?  Any advice would be helpful.  I have attached screenshots of the error messages
Parents Reply Children
