Hi everybody
I am desperately trying to export out my ConceptStation file to OpenRoads Designer to work on it further and with more tools. I followed the instructions on the wiki on exporting but I get an "export failed" error on just the .ird template drop file. Everything else says it exported without a problem, but that template drop file is pretty important...If I can't get it to work, I am pretty much back to square one and have lost days of work.
When I try to import the .ird file into OpenRoads Designer, I get an unexpected error that an "unexpected end of file has occurred. The following elements are not closed: Corridor, RoadwayDesigner, InRoads, Line 1, position 3942445".
I really need help on this issue. Do I uninstall and reinstall ConceptStation? Is there something wrong or damaged in the ConceptStation file that needs changed? Any advice would be helpful. I have attached screenshots of the error messages
Yes, that's it. I would be very thankful if you could. I didn't check the thread correctly, sorry for that, but it was the only one with the same error message as mine. My ORD version is 10.08.00.88.
