Could Openroads Designer display side toolbar just like Power Civil? I am not quite familiar with the ribbon interface on ORD, so I want to change back to side toolbar just like what Power Civil looks. See below picture. Some of our customers have the same question.
I searched similar questions, and found that V8i style Tasks could be displayed in MicroStation CONNECT Edition using the configuration variable MS TASKNAVIGATION CONFIGURATION.
The website is: https://communities.bentley.com/products/microstation/w/microstation__wiki/24481/how-to-display-the-v8i-style-tasks-dialog-in-microstation-connect-edition
And I tried this method on ORD but it did not work. Maybe there is other configuration variable that we could change in order to solve this problem?
Thank you for your help!
I've managed to get the Civil Tools within the v8i Task Navigation toolbar. But of work but possible.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
So I got my taskbar to work. But is there any way to turn on the usual shortcuts on the left for quick access. I have no shortcut letters on mine, which will rather make it almost useless to have the taskbar for me.
Under your Preferences, have you turned on "Position Mapping"?
MaryB
Thank you. That did the trick.
You're welcome :-)
