Could Openroads Designer display side toolbar just like Power Civil? I am not quite familiar with the ribbon interface on ORD, so I want to change back to side toolbar just like what Power Civil looks. See below picture. Some of our customers have the same question.
I searched similar questions, and found that V8i style Tasks could be displayed in MicroStation CONNECT Edition using the configuration variable MS TASKNAVIGATION CONFIGURATION.
The website is: https://communities.bentley.com/products/microstation/w/microstation__wiki/24481/how-to-display-the-v8i-style-tasks-dialog-in-microstation-connect-edition
And I tried this method on ORD but it did not work. Maybe there is other configuration variable that we could change in order to solve this problem?
Thank you for your help!
Is there anyway you can get the same tasks added into the taskbar. I use Civil tools the most but I can't find a way to add it. I just have the basic ones
If you click on FILE in your drawing and then down to SETTINGS you will find a box that says "Tasks" click on that and also make sure the box for "Tasks" is checked in the "Tool Boxes" box as well under User Settings. Once back into your drawing look for the V8 icon next to OpenRoads Modeling drop down menu in the top left corner of your screen. Click on the V8 drop down menu and click on dialog and the Task toolbar should pop up like pictured below.....
Hey Chris, if this still works, could you share how you were able to accomplish?
