Annotative Baseline Stationing and Annotations
Hello Everyone,
I have been searching online and in forums for an answer to this questions but cannot seem to find one.  Is there any way to set up baseline stationing and annotation so that it is annotative?  Currently, the workflow we use is to create multiple levels within our baseline file for the different baseline scales.  I do not really like this approach because if the baseline geometry changes then you need to go through all the various baseline scale levels and update the stationing and annotations accordingly, which can be tedious and error prone.  Right now I am trying to get my company to make the switch to start using InRoads SS4, mainly for is more dynamic capabilities when it comes to modifying/adjusting alignments/corridors/surfaces/etc. and what hoping that there may be a way with this newer version to also make annotations annotative.  I know that for AutoCAD baselines are not only dynamic but all the stationing (labels, tick marks) and annotations (PT/PC callouts, bearings) are also dynamic and annotative so that if you change the geometry or annotation scale everything updates accordingly.  I am hoping there may be a way to do something similar with SS4 but have not found any documentation on it yet.  If this still is not possible, will this functionally be available in the Connect edition?  Thank you.
Carl
  • I have not found SS4 to acknowledge Annotation Scale at this time. It either doesn't have that capability, or I haven't found that setting yet.
    This renders our standard text styles useless with SS4, and requires workarounds similar to what you describe (or just placing all that text into every sheet every time).
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Unfortunatly, that is what I thought.  However, I do think GEOPAK and MX both have the ability to do annotative labeling as long as the feature style has been set up correctly for the different annotation scales.  InRoads for whatever reason does not appear to have this capability which is quite frustrating and does not make sense to me.
  • The problem with Annotation Scale is crowding. Linear annotations, like Stationing might scale OK for scales less than 1"=100', but greater scales will be too crowded using the same spacing. And get above 1"=500' and the same thing happens with wider label spacing. Area labels are also effected by crowding. A label for an area of woods might be needed every 300' for one scale, but only every 500' for another and even greater spacing for even larger scales.
    AutoCAD allows you to set a range of scales for labels so that as scales increase, fewer labels appear. But their stationing labels for Civil 3D have the same problem. The ticks, offsets and text scale correctly but eventually are too crowded as the scales increase. These is currently no automatic fix. You have to create annotation styles for ranges of scales and manually swap them as the scales change between those ranges.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Chuck,
    Thank you for your input and I very much do understand your point for the need to have different styles based on the scale you are annotating.  As I mentioned, the way we do our baseline stationing and annotation now using InRoads SS2 is to have the different preferences set up for and additionally have different levels in our baseline file for the various scales.  I don't really like this because this stationing/anotation is not technically dynamic and physically tied to the baseline, therefore, if/when the geometry changes you have to go through and manually update the stationing for each of the baseline scales, which can be very tedious and be prone to errors if someone forgets to update a scale level.
    I started looking and working with InRoads SS4 and I actually thing this issue becomes more difficult with creating stationing and annotations for multiple scales.  The reason I say this because with SS4, it appears that stationing/annotation of a baseline is applied by assigning a style parameter to the baseline element that has the stationing/annotation preferences assigned to it.  The issue here is that when you assign thay style, the stationing/annotation is placed at the scale set in the inroads preference, but when it's placed, it is tied to the baseline and will update/change when the baseline changes.  Unlike terrain, you cannot override the display style of a baseline element (or at least not that I have found) therefore I am not sure how you can use the same baseline but have different stationing/annotation scales?  If you could set up separate styles and be able to override the baseline style when you reference it into another file then I think that would work. I think then the only other way then is to export the baseline back out to the native .alg format and station/annotate the way we have been, however, this then seems to remove the dynamic capabilites of the baseline which is very benificial..... I wish Bently had suggestions/best practices for handling this.  I may have to give them a call and see if they can suggest a better workflow for this.
Reply
  • Chuck,
