ORD Won't export to LandXML. only the center line and no lines that are created by a template?
Any Idea?
//Christiaan
5531.Test_19.zip
<?xml version="1.0" encoding="utf-8"?> <LandXML xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.1 http://www.landxml.org/schema/landxml-1.1/LandXML-1.1.xsd" version="1.1" date="2017-11-02" time="13:39:19" xmlns="http://www.landxml.org/schema/LandXML-1.1"> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA" /> </Units> <Application name="OpenRoads Modeler" version="10.00.00.00" manufacturer="Bentley Systems, Inc." manufacturerURL="http://www.bentley.com" /> <Alignments> <Alignment name="Kaigaten_R-Kinematic profil" length="155.561890" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten_R-Kinematic profil" state="proposed" /> <Profile> <ProfAlign name="ProfileByTemplate"> <PVI>0.000 2.335000</PVI> <PVI>155.562 1.559349</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="Kaigaten" length="155.820482" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten" state="proposed"> <Line> <Start>6700699.825747 297592.422749 0.000000</Start> <End>6700648.542524 297696.458808 0.000000</End> </Line> <Spiral spiType="clothoid" length="5.500000" rot="cw" radiusStart="INF" radiusEnd="50.000000"> <Start>6700648.542524 297696.458808 0.000000</Start> <PI>6700646.921093 297699.748135 0.000000</PI> <End>6700646.021076 297701.345952 0.000000</End> </Spiral> <Curve crvType="arc" rot="cw" radius="50.000000"> <Start>6700646.021076 297701.345952 0.000000</Start> <Center>6700602.456813 297676.807104 0.000000</Center> <End>6700644.635486 297703.657795 0.000000</End> </Curve> <Spiral spiType="clothoid" length="5.500000" rot="cw" radiusStart="50.000000" radiusEnd="INF"> <Start>6700644.635486 297703.657795 0.000000</Start> <PI>6700643.650677 297705.204792 0.000000</PI> <End>6700641.514230 297708.185446 0.000000</End> </Spiral> <Line> <Start>6700641.514230 297708.185446 0.000000</Start> <End>6700626.288174 297729.428015 0.000000</End> </Line> </CoordGeom> <Profile> <ProfAlign name="Kaigaten"> <PVI>0.000 2.335000</PVI> <CircCurve length="5.372551" radius="1500.000000">46.597 2.102013</CircCurve> <CircCurve length="3.581703" radius="1000.000000">69.780 1.903062</CircCurve> <CircCurve length="14.510312" radius="5000.000000">126.018 1.621871</CircCurve> <PVI>155.820 1.559349</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="Kaigaten_L-Kinematic profil" length="156.078525" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten_L-Kinematic profil" state="proposed" /> <Profile> <ProfAlign name="ProfileByTemplate"> <PVI>0.000 2.335000</PVI> <PVI>156.079 1.559349</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="Kaigaten_L-Sikkerhedsonne-400" length="156.144088" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten_L-Sikkerhedsonne-400" state="proposed" /> <Profile> <ProfAlign name="ProfileByTemplate"> <PVI>0.000 2.335000</PVI> <PVI>156.144 1.559349</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="Kaigaten_L-Sikkerhedsonne-800" length="156.209650" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten_L-Sikkerhedsonne-800" state="proposed" /> <Profile> <ProfAlign name="ProfileByTemplate"> <PVI>0.000 2.335000</PVI> <PVI>156.210 1.559349</PVI> </ProfAlign> </Profile> </Alignment> </Alignments> </LandXML>
What version of ORD are you currently running. Also could you provide the DGN file with the information you are trying to export to LandXML?
sorry I just saw the file, thanks
I just ran it on your data and here are my results:
<?xml version="1.0" encoding="utf-8"?> <LandXML xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-2.0 http://www.landxml.org/schema/landxml-2.0/LandXML-2.0.xsd" version="2.0" date="2017-11-02" time="09:12:34" xmlns="http://www.landxml.org/schema/LandXML-2.0"> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA" /> </Units> <Application name="OpenRoads Modeler" version="10.00.00.00" manufacturer="Bentley Systems, Inc." manufacturerURL="http://www.bentley.com" /> <Alignments> <Alignment name="R cant" length="155.702604" state="proposed" staStart="0.000"> <CoordGeom name="R cant" state="proposed" /> <Profile /> </Alignment> <Alignment name="L cant" length="155.937811" state="proposed" staStart="0.000"> <CoordGeom name="L cant" state="proposed" /> <Profile /> </Alignment> <Alignment name="L_Kp" length="156.078361" state="proposed" staStart="0.000"> <CoordGeom name="L_Kp" state="proposed" /> <Profile /> </Alignment> <Alignment name="Kaigaten" length="155.820482" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten" state="proposed"> <Line> <Start>6700699.825747 297592.422749 0.000000</Start> <End>6700648.542524 297696.458808 0.000000</End> </Line> <Spiral spiType="clothoid" length="5.500000" rot="cw" radiusStart="INF" radiusEnd="50.000000"> <Start>6700648.542524 297696.458808 0.000000</Start> <PI>6700646.921093 297699.748135 0.000000</PI> <End>6700646.021076 297701.345952 0.000000</End> </Spiral> <Curve crvType="arc" rot="cw" radius="50.000000"> <Start>6700646.021076 297701.345952 0.000000</Start> <Center>6700602.456813 297676.807104 0.000000</Center> <End>6700644.635486 297703.657795 0.000000</End> </Curve> <Spiral spiType="clothoid" length="5.500000" rot="cw" radiusStart="50.000000" radiusEnd="INF"> <Start>6700644.635486 297703.657795 0.000000</Start> <PI>6700643.650677 297705.204792 0.000000</PI> <End>6700641.514230 297708.185446 0.000000</End> </Spiral> <Line> <Start>6700641.514230 297708.185446 0.000000</Start> <End>6700626.288174 297729.428015 0.000000</End> </Line> </CoordGeom> <Profile> <ProfAlign name="Kaigaten"> <PVI>0.000 2.335000</PVI> <CircCurve length="5.372551" radius="1500.000000">46.597 2.102013</CircCurve> <CircCurve length="3.581703" radius="1000.000000">69.780 1.903062</CircCurve> <CircCurve length="14.510312" radius="5000.000000">126.018 1.621871</CircCurve> <PVI>155.820 1.559349</PVI> </ProfAlign> </Profile> </Alignment> <Alignment name="Kaigaten_L-Sikkerhedsonne-400" length="156.144088" state="proposed" staStart="0.000"> <CoordGeom name="Kaigaten_L-Sikkerhedsonne-400" state="proposed" /> <Profile /> </Alignment> </Alignments> </LandXML>
I used the 2.0 Land.XML version.
Thanks, but there isn't a vertical profile except for Kaigaten the rest is empty?
Correct, there are no profiles associated to the horizontal elements. You can select the horizontal and look at the properties and you will see not profile listed. So nothing to export.
