I am trying to annotate drainage profile. However, I want the invert in and invert-out text rotated vertically instead of horizontal with the sheet.
How can I display the inverts vertically?
First, make sure that your style lock is off by going to Tools > Locks > Style Lock. Then, go to Evaluation > Profile > Annotate Drainage Profile. Double click on the Symbology that you are wanting to edit.
Then, change the Rotation to suite your preference. Click OK, then Apply.
Thanks Holly. That was very helpfull.
However, when I change the sympology text to rotate 90 deg, it also made the other pipe text data to rotate.
Instead of just rotating the inverts 90, it also rotated the pipe diam, pipe material, pipe slope.
Is there a way to just rotate the inverts elevations itself and leave the other pipe info at zero rotation?
Thanks.
You could create a selection set of the items you want to rotate 90 degrees, then use the MicroStation Tool under Tools > Manipulate > Rotate to rotate the text. The functionality to be able to rotate only the invert 90 degrees is available in OpenRoads Designer. I recommend considering upgrading to the latest software to be able to take advantage of all that it has to offer.
I have a drainage network with connecting pipes along the main trunk line. For creating drainage profiles ( Inroads S&S in SS4), how can I create pipe profiles of the entire network including the connecting pipes all in one display? I think Geopak drainage currently does this already.
