Problem...
After I visualize my Geopak elements more than a few times the visualization stops working. In order to use visualization I have exit Microstation and start another session. This is extremely unproductive and happens quite often. Further more any of the Geopak elements that were visualized before the glitch are now permanently stuck in the cad file. Any ideas on what is causing this?
Cliff
Microstation V8 ver.08.05.02.70
Bentley Civil 2004 edition 08.08.02.81
Cliff,
I'm not sure why that would be happening. It could be a software problem or it could be a data or workflow issue, but there is no way to know wihout looking at your data. I would suggest logging a call with support and supplying them your data, then we could take a look and see if we can reproduce it to figure it out.
Derricke
