Hi
I would like to import my SUP files with superelevation definition to OpenRoads Designer. There is an option to import superelevation from SEP and SUP files. When I choose SPE files I am prompted to pick up specific file. However when I choose to import SUP file I am prompted to select folder. when I select folder nothing happens, when try to select it again, software crashes and I get NetFramework error.
Has anyone pushed sup files forward to ORD with a success here?
Adam
Hi Adam,
This functionality has been addressed in our upcoming update.
Sanders
You mean update 2 that is expected any day now?
That is correct, Update 2.
I have Update 2 installed. Still can nto import sup files. There is a tool but the same result as with Update 1. I am prompted to point folder with sup files, once done, I get error and nothing is imported.
Have you ever managed to import sup files to ord xml?
Please sample file attached. I changes file extenison so you need to replace txt with sup.
*Tabela przechy�ek i ramp *.sup *zbudowana wg DZ.U.Nr43 par. 21.3 * * dla dr�g: * klasa Z * bez kraw�nik�w * pr�dko�� projektowa 60 km/h * rampa na d�ugo�ci: * krzywej przej�ciowej lub * prostej przej�ciowej, Lmin=30 * * oznaczenia: * nc - pochylenie daszkowe jak na prostej * rc - pochylenie jednostronne jak na prostej * * w programie odl. kraw�dzi jezdni od osi obrotu wybieara si� * w oknie "Dodaj sekcj� definicji przechy�ki" w polu "Liczba pas�w": * Dwa - jezdnia 2-pasowa, odleg�o�� kraw�dzi od osi * jeden pas (poni�ej przedostatnia kolumna) * Cztery - jezdnia 4-pasowa, odleg�o�� kraw�dzi od osi * wynosi dwa pasy (poni�ej ostatnia kolumna) * * *typ ? Promie� Przechy�ka D�. prostej przej�ciowej * przy odl. kraw�dzi od osi obrotu * 1 pas 2 pasy * R q L2 L4 Curve 100000 nc 0 0 Curve 600 nc 0 0 Curve 599 rc 30 30 Curve 500 rc 30 30 Curve 499 0.025 30 30 Curve 388 0.025 30 30 Curve 387 0.03 30 30 Curve 325 0.03 30 30 Curve 324 0.035 30 30 Curve 275 0.035 30 30 Curve 274 0.04 30 30 Curve 238 0.04 30 30 Curve 237 0.045 30 30 Curve 213 0.045 30 30 Curve 212 0.05 30 30 Curve 188 0.05 30 30 Curve 187 0.055 30 30 Curve 163 0.055 30 30 Curve 162 0.06 30 30 Curve 144 0.06 30 30 Curve 143 0.065 30 32 Curve 131 0.065 30 32 Curve 130 0.07 30 34
Did you figure that out?
