Microstation 08.11.09.832 fails to open with Microsoft Outlook open. Generates application error log:
Faulting application name: ustation.exe, version: 8.11.9.832, time stamp: 0x56fe8d51 Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000Exception code: 0xc0000005Fault offset: 0x76cfbca4Faulting process id: 0x1b40Faulting application start time: 0x01d36384a27a33a5Faulting application path: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exeFaulting module path: unknownReport Id: e4f30405-cf77-11e7-b067-5c260a6025b8
If I have Outlook closed the Application launches fine, and I am able to open Outlook. This is a Windows 7 workstation with Office STD 2013.
Thank you,
This would be better posted on the MicroStation forum, rather than the Civil forum. https://communities.bentley.com/products/microstation/f/microstation-forum#pi25830=1
Answer Verified By: Jamie Keys
I am not seeing an option to remove this post.
Don't worry about removing it - you never know, someone on this forum may know a solution to your issue.
