Dear Users,
my menu bar was dissapered and can`t be add again.(image below). Just right clicking in menu nothing change...
Is there any chance to reset software to default settings ( not xin)?
And how to do this>>
Thanks for help
S
Sebastian, wow, that's an interesting one! Have you looked around to see if it just got 'undocked'? If you right click in that blank area at the top, do you get the Locks toolbar and Customize options?
thanks for fast respond.
It`s no got 'undocked'.
There were few bars and I can get to the Locks toolbar and Customize options.
And Customize options not include menu bar ;/
So, any ideas hot to reset settings in Inroads?
Sebastian, the answer might be in deleting the Registry Key that establishes the position or location for that (it might be called the Menu Bar), but I can't seem to find it at the moment. It's probably somewhere under HKEY_CURRENT_USER\Software\Bentley\InRoadsGroup\Applications\Version 8.11.9 and either under DialogPos or Toolbars or Docking. Maybe Bentley can chime in. I'm sure someone there would know where that key is. ...it's worth a try when a toolbar is lost because removing the Reg Key resets it back to it's default size and position. ...otherwise ... uninstall ... reinstall? : \
Or, if you can get to Customize, maybe a Reset All would work.
Answer Verified By: Sebastian Grabiński
... or even just highlighting the Menu Bar under Customize and then Reset.
