Hi all. I am working in Power Rail Track SS4, where I design drainage systems. Things are running fine (as fine as SUE can run), but when I try to either open a .cel file, or a drawing .dgn file with my Microsstation SS3 I get the following error in a black box:
"OS could not load C:\PROGRA~2\Bentley\PROJEC~1\bin\v811\mcm.dll, error 127.MDL Loader: Unable to load library (DLL or MDL shared library) mcm"
And a Microsoft .NET Framework with the following:
************** Exception Text **************System.Runtime.InteropServices.SEHException: External component has thrown an exception. at ProtectAppPermissions.{ctor}(ProtectAppPermissions* , Boolean ) at oldMdlMain(Int32 argc, SByte** argv) at Bentley.MicroStation.PublishDgn.PublishDgnAddIn.Run(String[] commandLine) at Bentley.MicroStation.AddIn.Load(String[] commandTail, IntPtr mdlDesc)
We are working from Project Wise, and I don't know if that might be the problem, or if there is something wrong in the user settings somewhere.
If anything else is needed from me, in order to help me find out where I'm messing up, please let me know and thank you in advance Jan Holdorff Nielsen
Bringing an update to my issue. My company works for different clients, and sometimes these clients demand that we work on their ProjectWise server.When I right click a document and select "open with" and choose Microstation SS3, I can open documents from the clients server. But when I try and do the same on one of our own servers I get the error.Today I tryed letting a colleague login on my PC (using his windowslogin), and he has no problems opening files with microstation from the exact same server I can't open them from.
This leeds me to believe I have a problem in my user configuration settings somewhere. I'm just not bright enough to figure out how I could go about checking/changing these settings.
