I have annotative cells drawn in from a survey field book. by default, my base drawing is set to 100 scale. I have this file referenced into a sheet file, set at a 20 scale drawing. Using the Print the Cells hare annotated, to the 20 scale drawing. But, when I use Print org, the Cells revert to the 100 scale size.
to Kevin O. I do agree, changing the base to a drawing scale to match the sheet size, is a fix, but my situation involves use of the Survey file, referenced into multiple sheet sets. The key issue here , is that the sheets created are at different scales. So, i have this 1 survey base, referenced into a 20 scale, 50 scale and 100 scale.
thank you Alicia. You hit the nail on the head.
The way we dealt with it was to create pdf sets of each of the scales of sheets, after changing the survey file to the corresponding scale, and then combining them into a single set to print. It works but it is a pain if something changes.
You're welcome, just wish it was better news.
