Hi All,
I would like to migrate our custom reports from SS3/SS4 to OpenRoads Designer Connest. We have a number of reports either customized or translated to other languages. What is ther best way to push these forward to ORD? I thought it would work but unfortunatelly we get errors on every single report, sth about non definied variables, sth about lacks in format.xls, etc.
Can not imagine creatng these reports from scratch.
Adam
Hi Adam,
Here's some info that should help - https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/135195/xsl-report-format-change-in-ord
Unfortunately a bit painful to update the variables, but no recreation from scratch required...
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 17 | ProjectWise CE 3.4
Answer Verified By: Adam Wieczorek
Mark,
thank you! as always your help is outstanding!
Hi Adam
In Update 2 which is now out, refer download site. When installed if you look under the configuration folder, then Organization-Civil, then Migration Utilities, there is a folder called XSL Style Sheet Converter.
Ross
ORD 2021 Release 2
Thanks, Will give it a try as soon as I have update 2 installed.
