My ditches/end conditions were working fine, but suddenly disappeared from 7 (out of 30) corridors containing different template drops.
One corridor could be restored by simply processing the corridor, but the other corridor, containing the same template drop, was not restored by this action. The ditches, however, did come back when creating a new corridor, using the excact same template drop. I have also tried changing, reloading and reactivating the terrain without any luck. I therefore suspect the corridor to be the problem, rather than the template drop or terrain.
I have included several screenshots of the problematic corridor, the new corridor created on top of the old one and the used template drop (just in case).
I would really much prefer not having to remodel all my corridors, so is there anyway, I can repair the ones I have and get back my ditches?
Do you recall anything just prior to them disappearing? Did you make a change in one that would have affected the other corridors?
I think I might have changed the active surface, but I have done that many times before without any problems.. I also added a new substrata terrain right about the same time. I just don't understand why it only affected a few of the corridors.
Try to add Target Aliases for all targets used by your ditches, eg. vertical ditch alignemnts and terrain models.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
The same thing just happened to me and I can't figure out why. This is the most frustrating thing after spending hours designing them. I believe it's related to the out of system memory error. If you find a solution please let me know.
