How to Create Custom SUDA Drainage Nodes
I am in charge of getting our company switched over from PowerGEOPAK SS2 to PowerGEOPAK SS4.  We have gone through some Bentley training and watched online tutorials and read information through here and general Google searches.  I thought I had a pretty good handle on things but now realize I am still missing some information.
My goal is to create custom SUDA nodes which are in accordance with our client's standards, can be used in design, AND exported back to Geopak Drainage for plan production purposes.
The custom cells we have created so far, seem to work within SUDA.  However when we go to export to Geopak Drainage, we get errors, that I cannot get rid of.  The only successful export I have accomplished has been by utilizing the built-in nodes in the examples workspace provided with the PowerGEOPAK installation.
I have scoured the internet and have not found any useful information.
Does anyone have a document outlining the creation of a custom cell from beginning to finish so that I can see what steps I am missing?  Any help would be appreciated.
Thank you,
Vince
  • Hey Vince: The workflow to export to GDF file can be a little tricky to make it work mostly seamlessly.  Here's how it works:
    • On the export, it tries to match the Inlet Catalog item (not feature definition) in SUDA to a GEOPAK Drainage item name in the drainage library. This is a simple text string matching. If a match is found then the GDF file will display the nodes as expected as though you had created the elements in geopak drainage originally.
    • If no match is made then you will have to clean it up manually after the export. Headwalls are particularly troublesome in my experience. I nearly always need to clean up a handful of the headwalls.
    Side note: In my opinion, take it for what's worth, the export to GDF should ONLY be used for producing profiles and the drainage labeler.  Using the exported data for drainage computations is just asking for trouble. The calculations should work, but there will inevitably be slight differences in the results which is an invitation for the raindrop chasers to challenge the validity of the design.
    Robert Garrett
    Senior Consultant
    www.envisioncad.com
