To Whom it May Concern,
Is it possible within Power InRoads SS4 to only model a particular windowed area (E.g. inside a fence) for a section of your roadway corridor versus the entire corridor? Was this option excluded with SS4? This would help with reducing the wait time for the entire corridor to process. Using the lock - deactivate/activate rule helps to some extent, but having the option to isolate an area for minor adjustments would be welcomed as well.
Additional information ==> The modeler in InRoads SS2 would allow you to zoom into a particular area of your project and then process that particular station range versus the entire corridor. Thus cutting down on your time waiting for the entire corridor to process.
Appreciate your time with my question.
Larry Nechanicky
Great idea Larry I would support this enhancement. I come from a MX background so had no idea that Inroads used to do this.
Ross
