I imported terrain and an aerial from the Geo Coordination Services and that worked fine but I recently received a .tin from the surveyor and I was able to import that just fine and it came in at the same location as the terrain model from the Geo location Services, but now I cannot get any raster images to import! Everytime I try and import a jpg I get the failure message that says "No GCS found" even though everything has been in the same coordinate system the entire time.
When I try and creating a new ConceptStation file and choose the option to "Import local files" without using Geo coordination services, the .tin file from the surveyor comes in fine but the jpg does not import at all. I have a world file associated with the jpg as well.
Thank you
I never got the dataset from Chris. Could you share your dataset with us so that we can try to understand what is going on?https://communities.bentley.com/help/w/be_communities_help/7079/communities-secure-file-upload
Good to hear that it's working. Thanks for posting your response.Cheers!
