Unable to edit horizontal alignment and handles are enabled
I am currently trying to edit a horizontal alignment and for some reason handles are not showing up. The element itself is not locked and handles are enabled in the file. Any ideas as to why this is happening and/or how to fix the issue I am currently facing. I have attached a photo of one of the alignments below.
I have found a post with similar issues and a probable solution: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/14441/portion-of-horizontal-alignment-does-not-have-element-handlers-or-manipulators. Although the post does mention a solution I have a follow up question as a result of dropping the element as advised in the post referenced above. By dropping the complex element any rules from other design elements will be lost as a result. This brings me to my question, is there a way to re-establish the rules to the new alignment?
