After watching the SIG this morning I tried the Bing Maps raster attachment, first in Microstation V8i which was successful, and then in ORD. ORD doesn't seem to work. The error says One Raster Reference failed to attach. Is the configuration variable the same in both applications?
Found the problem - needed to assign a Geographic Coordinate System.
