I am getting the error " An error occurred: Authentication token is expired. Cannot connect." when I try to stream Bing Map into my file. I can't find any documentation and how or where this needs to be configured for it to work. Also it seems odd that Update 7 now works without needing you to acquire and configure a token but ConceptStation does not. Who has this working, what if anything did you do setup-wise to make it work?
Thank,
Terry
Basically, the application needs to obtain your Bentley CONNECT authentification token from CONNECTION Client in order to use Bing Maps. I'm surprised you are getting this error, we have safeguards to make sure we don't let the token expired. I'd like to understand better how you obtained this error but I believe that simply restarting Concepstation should fix your issue.
Simon
