Hi guys, I am trying to work with Bentley PowerCivil for a university project. I need to extract in dwg from my model the vertical profile of the track and the vertical profile of the terrain model. I tried to export in dwg from File -> Export -> DGN,DWG,DXF but I obtain only the x,y view (planimetry) or the 3d model. How can I export to dwg the profiles I need? I didn't find any information on this in the forum.
Thank you very much
Try to create and export profiles using native.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi Andrea
You may wish to consider exporting to LandXML format. Refer to http://www.landxml.org/
Find attached sample file which can be open with Notepad
jan96down.xml
Horizontal alignment is denoted by <CoordGeom>
<Alignment name="jan96down" length="110214.776597" staStart="0.000035" desc="ctrl down line, alp 18/7/96" state="proposed"> <CoordGeom name="jan96down" desc="ctrl down line, alp 18/7/96" state="proposed"> <Line length="532.195261" dir="5.804448132" staStart="0.000035"> <Start code="POB"> 62969.158200 10134.120310 0.000000 </Start> <End code="PC"> 63441.522666 9888.959939 0.000000 </End> <Feature code="Line"> <Property label="style" value="Default"/> </Feature> </Line> <Curve rot="cw" length="129.706120" chord="128.882806" dirStart="5.804448132" dirEnd="6.195129216" staStart="532.195296" radius="332.000000"> <Start code="PC"> 63441.522666 9888.959939 0.000000 </Start> <Center code="CC"> 63594.461351 10183.635623 0.000000 </Center> <End code="CS"> 63565.264494 9852.921935 0.000000 </End>
<Curve rot="cw" length="179.053272" chord="179.026697" dirStart="1.297270304" dirEnd="1.356954728" staStart="109714.856279" radius="3000.000000"> <Start code="SC"> 17434.075767 99213.926063 0.000000 </Start> <Center code="CC"> 14545.602549 100024.310211 0.000000 </Center> <End code="CS"> 17477.271191 99387.663547 0.000000 </End> <Feature code="Curve"> <Property label="style" value="Default"/> </Feature> </Curve> <Spiral length="80.000000" radiusEnd="INF" radiusStart="3000.000000" rot="cw" spiType="clothoid" dirStart="1.356954728" dirEnd="1.370288062" staStart="109893.909551" constant="489.897949" theta="0.013333333" totalY="0.355551" totalX="79.998578" tanLong="53.333830" tanShort="26.667118"> <Start code="CS"> 17477.271191 99387.663547 0.000000 </Start> <PI code="PI"> 17482.930368 99413.723266 0.000000 </PI> <End code="ST"> 17493.552731 99465.988578 0.000000 </End> <Feature code="Spiral"> <Property label="style" value="Default"/> </Feature> </Spiral> <Line length="240.867080" dir="1.370288062" staStart="109973.909551"> <Start code="ST"> 17493.552731 99465.988578 0.000000 </Start> <End code="POE"> 17541.525610 99702.030000 0.000000 </End> <Feature code="Line"> <Property label="style" value="Default"/> </Feature> </Line> </CoordGeom>
</CoordGeom>
Vertical alignment is denoted by <Profile>. For example,
<ProfAlign name="down" desc="down line VAlg 20.6.96"> <PVI> 0.000000 21.519000 </PVI> <ParaCurve length="25.411274"> 427.704000 22.792000 </ParaCurve> <ParaCurve length="81.165628"> STA Elevation </ParaCurve>
<ParaCurve length="118.518387"> 109280.698000 66.620600 </ParaCurve> <PVI> 110214.777000 56.888080 </PVI>
Gary
Answer Verified By: Andrea Bernardini
It's not very convenient to create another time the profiles. Anyway I managed to do this following Gary Chien's answer. Thank you
Thank you very much!
