About Openroads CpnceptStation (Version: cnst10000645en )
I find that the bridge is invisible when placing a bridge, after importing the. alg file. (The green map is from. tin file.)
How to do?Obviously, it is not by hide or unhide tool.
Please watch the following video.
https://youtu.be/PTrTFhTzPco
Looking forward to your reply!
Zhengpeng
Thanks for your response.One suggestion for ConceptStation:
Adding Favorite Coordinate System into the context menu, because without the Favorite Coordinate System, you must search the Coordinate System every time when creating a project,obviously it is not convenient and is inefficiency.On the contrary, you can find the Favorite Coordinate System setting in OpenRoads Designer and Power Inroads.
Hope you development team can do this, and can issue the next CS as soon as possible.
